pola niestandardowe - pobieranie z filmweb
athe
Post by athe »
jak pobrać dane z filmweb.pl do pól niestandardowych, może ktoś podpowiedzieć?
how to take info from filmweb to non standard fields? Sorry for my english
If you want to store an info into another field than what the script uses you can search for the SetField calls in the script and replace them by SetCustomField (see the help for the right syntax).
But if you want to import extra info not yet imported by the script, it will require bigger changes.
athe
Post by athe »
Thank You for fast reply, antp. I wonna take info from actorsfield. They are info about screenwriter, music, cinematographer, etc. I make new non standard fields for these info. This is parts of a filmweb script:
Value := '';
	if GetOption('CzyDodDaneWPoluAktorzy') >= 2 then
 	// Scenariusz (2009-02-17 by jlatk)
  	Value := GetMaterials(Page, 'role-screenwriter');
    if (Length(Value) > 0) then
      Value := GetField(fieldActors) + #13#10 + 'Scenariusz: ' + Trim(Value) + '; ';
    	SetField(fieldActors, Trim(Value));
	// Muzyka (2009-02-17 by jlatk)
  	Value := GetMaterials(Page, 'role-music');
      Value := GetField(fieldActors) + #13#10 + 'Muzyka: ' + Trim(Value) + '; ';
    	SetField(fieldActors, Value);
	// Zdjęcia (2009-02-17 by jlatk)
  	Value := GetMaterials(Page, 'role-cinematographer');
      Value := GetField(fieldActors) + #13#10 + 'Zdjęcia: ' + Trim(Value) + '; ';
	// Montaż (2009-02-17 by jlatk)
  	Value := GetMaterials(Page, 'role-montage');
      Value := GetField(fieldActors) + #13#10 + 'Montaż: ' + Trim(Value) + '; ';
	// Scenografia (2009-02-17 by jlatk)
  	Value := GetMaterials(Page, 'role-productionDesigner');
      Value := GetField(fieldActors) + #13#10 + 'Scenografia: ' + Trim(Value) + '; ';
	// Kostiumy (2009-02-17 by jlatk)
  	Value := GetMaterials(Page, 'role-costumeDesigner');
      Value := GetField(fieldActors) + #13#10 + 'Kostiumy: ' + Trim(Value) + '; ';
	// Dźwięk (2009-02-17 by jlatk)
  	Value := GetMaterials(Page, 'role-sound');
      Value := GetField(fieldActors) + #13#10 + 'Dźwięk: ' + Trim(Value) + '; ';
	ActorsPage.Free;
when i replace SetField with SetCustomField i have error.
Value := '';
    //begin
   //   Value := GetField(fieldActors) + #13#10 + 'Scenariusz: ' + Trim(Value) + '; ';
    	SetCustomField(fieldScenariusz, Trim(Value));
   // end;
admas
Post by admas »
Zamień linie w skrypcie na poniższe
  	SetField(fieldWriter, Trim(Value));
  	SetField(fieldComposer, Trim(Value));
Pobiera bezpośrednio do nowych pól, a nie do pola obsada
  	SetCustomField('Cinematographer', Trim(Value));
  	SetCustomField('Editor', Trim(Value));
  	SetCustomField('ProductionDesigner', Trim(Value));
  	SetCustomField('CostumeDesigner', Trim(Value));
  	SetCustomField('Sound', Trim(Value));
Musisz mieć pola niestandardowe z tagami: Cinematographer, Editor, ProductionDesigner, CostumeDesigner, Sound, aby pobrać do nich wartości, a nie do pola obsada.
athe
Post by athe »
Pięknie dziękuję za odpowiedź. Zmiana (change)
SetCustomField(fieldEditor, Trim(Value));
na (to)
pięknie załatwiła sprawę. Wielkie dzięki! Working perfectly, thank you very much!
