I am trying to edit the datapath variable in index.html so that I can store my database files and template files on my NAS and view the html through any local device through wifi. Android tablet, android phone or Wii.
I have tried using various UNC paths but am not having any luck.
I have tried
file:\\\\\
file:\\
http:\\
all with the servername and the IP address.
All I get is "Please Wait! Loading of movie database in progress"
Has anyone done this successfully?
Any ideas?
Thanks Rod
View over local wifi
rod
If that has to be posted in another thread, you should rather go post it there then - I do not think that the forum has a feature for merging threads.
About the problem, URLs use "/" and not "\".
However UNC paths used without file/http prefix use "\" and should be in the form \\machine\path\file
http:// is only available if you have a http server running.
In other cases file:// might work, but what is the full path syntax that you used?
rod
