ExtraPicture
J
ExtraPicture
Post by J »
function GetExtraPicture(extraIndex: Integer; address: string): Boolean;
stores in the catalog. How can I store them in picture path or catalog path?
Or do I have to export?
EDIT:
solved. It is set in the preferences, but only works if you have a catalog name :ha:
