folks,
here is an update for all of the "blue series" templates using the new movie extras from AMC v4.2. Just extract the dir in your templates folder.
You can furthermore use the old templates, but I recommend to use the new version when you update your AMC.
This update includes the following templates:
Blue Basic
Blue 3
Blue 5
Blue Background 1-3
The templates uses the extra category "Stills" and "Backgrounds", so you have to assign these categories to your pictures.
The templates use the first five pictures of "Stills" and the first one of "Backgrounds".
You can set the on-top-of-picture text color of Background templates in extra field "description" of first background pic in #RGB-format (e.g. aa90fc).
These templates are optimized for using with 16:9 or 16:10 monitors, well just try it. You find example pictures in my former topics.
have fun.
Blue (v4.2).zip
