Merging Categories
Nikolaus
Merging Categories
Post by Nikolaus »
Categories of movies can have different values but same meanings, e.g. 'Sci-Fi' and 'Science Fiction' - or different languages. To join these categories together to one category I have written a little script. You have to write your wishes into the script code - it's not very smart, but easy.
Authors=Nikolaus Mueller-Buechele
Title=Category replace
Description=replaces values of category, e.g. to combine different languages
Site=forum.antp.be/phpbb3/profile.php?mode=viewprofile&u=5684
Language=?
Version=1.0
Requires=
Comments=You have to  edit the script!
License=Free
GetInfo=0
RequiresMovies=1
CatSep=0|0|0=Categories separated by comma (default)|1=Categories separated by slash
[Parameters]
program CategoryReplace;
(* Script to merge categories with different values - e.g. different languages
   You have to define the values of concerning categories. *)
  i, catpos : integer;
  CatSeparator, CatField, CatToChange, LeftOfCat : string;
  CatList : TStringList;
  CatList := TStringList.create;
  set values: IT'S UP TO YOU!
  You have to define couples of values:
  the first value is the category you want to change - the index number will be even,
  the second value ist the category you want to join with - the index number will be odd
  Syntax:
    CatList.add('<first value>');
    CatList.add('<second value>');
  CatList.add ('Sci-Fi');
  CatList.add ('Science-Fiction');
  CatList.add ('Family');
  CatList.add ('Kinder-/Familienfilm');
  CatList.add ('Grusel');
  CatList.add ('Horror');
  CatList.add ('Adventure');
  CatList.add ('Abenteuer');
  CatList.add ('War');
  CatList.add ('Krieg');
  CatList.add ('Music');
  CatList.add ('Musikfilm');
  CatList.add ('Musik');
  CatList.add ('Romance');
  CatList.add ('Liebe/Romantik');
  CatList.add ('Romanze');
  CatList.add ('Sport');
  CatList.add ('Sportfilm');
(* end set values
  //get separator of multiple categories
  case GetOption('CatSep') of
    0: CatSeparator := ',';
    1: CatSeparator := '/';
  for i:=0 to CatList.count -2 do
  //break if index is odd
    if i mod 2 = 1 then
      continue;
    //the value to change (=CatToChange) must be a substring of fieldCategory,
    //delimited with CatSeparators or start-/end-of-field
    CatField:=trim(GetField(fieldCategory));
    CatToChange:=trim(CatList.GetString(i));
    CatPos:= pos(CatToChange, CatField);
    while CatPos > 0 do
      LeftOfCat:=trim(copy(CatField,1,CatPos-1));
      // preserve rest of category list
      Delete (CatField,	1, CatPos+ length(CatToChange)-1);
      CatField:= trim(CatField);
      (*check: substring in front of CatToChange is empty or ends with separator - AND -
               substring behind of CatToChange is empty or begins with separator
        if true, replace value of category.*)
      if ((CatPos=1) OR (copy(LeftOfCat,length(LeftOfCat),1)=CatSeparator)) AND
        ((pos(CatSeparator, CatField)=1) OR (CatField='')) then
        SetField(fieldCategory, StringReplace( GetField(fieldCategory), CatToChange, trim(CatList.GetString(i+1))));
  CatList.Clear;
  CatList.Free;
The language code is '?', but I would encourage to introduce a new code 'TOOLS' for all the scipts which enhances dates without getting information from the internet, e.g. 'Find Duplicates', 'Remove BadChars' etc.
