[REL]Script to delete undesirable commas
Nikolaus
Post by Nikolaus »
Some scripts deliver strings with double commas or with comma at the end. This script deletes these commas in all string fields.
program CorrComma;
  StringUtils1;
  MyField: string;  // contents of a database field
  MyFieldLen: integer; // length of MyField
  Position: integer; // position of a char
  i: integer; //counter
  nFields: integer; // number of fields
  nFields := GetFieldCount();
  if nFields < 1 then exit;
  Position:=0;
  MyField :=' ';
  MyFieldLen := 0;
  for i:= 1 to nFields do
    If GetFieldType(i) = 'ftString' then
      MyField := trim(GetField(i));
      MyFieldLen := length (MyField);
      // delete comma at the end of string
      while copy(MyField,MyFieldLen,1)=',' do
        MyField := trim(copy(MyField,1,TLen-1));
      // change double comma to single comma
        // without space between commas
      while pos(',,', MyField) >0 do
        Position:=pos(',,', MyField);
        MyField := copy(MyField, 1, Position) + copy(MyField, Position+2, MyFieldLen-Position-1);
        // with space between commas
      while pos(', ,', MyField) >0 do
        Position:=pos(', ,', MyField);
        MyField := copy(MyField, 1, Position) + copy(MyField, Position+3, MyFieldLen-Position-2);
      SetField (i, MyField);
Post by soulsnake »
Thank Nikolaus.
There is just a little mistake on fields loop (first field starts to 0).
I also add some optimisations ;).
program CorrComma;
  for i := 0 to nFields-1 do
    if GetFieldType(i) = 'ftString' then
      MyFieldLen := length(MyField);
      // delete comma and space at the end of string
      while (MyFieldLen > 0) do
        if (StrGet(MyField, MyFieldLen) = ',') or
          (StrGet(MyField, MyFieldLen) = ' ') then
          MyFieldLen := MyFieldLen - 1
          break;
      MyField := copy(MyField, 1, MyFieldLen);
      MyField := StringReplace(MyField, ',,', ',');
      MyField := StringReplace(MyField, ', ,', ',');
Re: [REL]Script to delete undesirable commas
Nikolaus wrote:Some scripts deliver strings with double commas or with comma at the end. This script deletes these commas in all string fields.
Wouldn't it be good to also fix these scripts then? :D
Nikolaus
[REL]Script "OFDb - IMDb - TMDb - mod"
Post by Nikolaus »
The Scipt "OFDb - IMDb - TMDb - mod" fills the database field "producer" with double commas as separator.
You can fix it by inserting at line 505:
Value := StringReplace(Value, ',,', ',');
Value := StringReplace(Value, ', ,', ',');
(Thx to soulsnake)
Note: This is a patch only to change the result. I'm not enough familiar with Pascal to find out the reason for the double comma separators.
Rather line 507, no?
i.e. just after the "until", to do it only once, after exiting the loop.
Nikolaus
Post by Nikolaus »
:??: we have different computers. my computer lists "until" at line 504.
anyway, the updated script looks like I intended it. ;)
Indeed. I guess I was tired yesterday :??: (or not yet fully awake)
