Managing fields
Kalambata
Managing fields
Post by Kalambata »
There are a few original fields that I don't use at all. On the other and I need to use new fields. I know how to add new fields.
Is it possible to manage original fileds (add, modify or delete them?).
TY
You can't change the original files, but you can add custom fields. I think the procedure for creating & managing these was described in the help file (that was done by soulsnale/Mickael, not by me)
Post by soulsnake »
Is it possible to manage original fields (add, modify or delete them?).
No, you can not manage original fields, sorry.
But you can rename them using translation file if you really want to use them for other purposes ;).
Kalambata
Post by Kalambata »
soulsnake wrote:Hi,
Thank You for your answer.
I added 4 new fields and called them ACT1, ACT2, ACT3 and ACT4
In HTML template I used $$ITEM_ACT1, $$ITEM_ACT2, $$ITEM_ACT3 and $$ITEM_ACT4 but those items are not shown.
$$ITEM_YEAR, $$ITEM_DIRECTOR and all the original fields are O.K.
What did I do wrong?
Post by soulsnake »
This is explained in help file (F1 > Export to HTML) :D :
$$ITEM_CF_ + custom field TAG in upper case = Custom field value
$$LABEL_CF_ + custom field TAG in upper case = Label of custom field
So for you, it is : $$ITEM_CF_ACT1, $$ITEM_CF_ACT2, $$ITEM_CF_ACT3 and $$ITEM_CF_ACT4
Also, you can use HTML Editor in AMC to edit templates.
You will have menus to include fields in template easier ;).
Kalambata
Post by Kalambata »
soulsnake wrote:Hi,
Thank You
