Huge Request List - Possible Ideas
NoFiX
Post by NoFiX »
First off, I love the Ant Movie Catalog. It's an amazing piece of software that I myself have been looking for, for so long. Anyways, thanks, here are a few requests:
-Colored text; This would be great for seperating fields in the same field box if the case ever needed to arise. Or maybe even just different fonts, ie. Italics / Bold.... etc.
-Addition of user created fields, with manipulation of their placement as well. I have many different fields I would love to add, also remove, this would be such a huge improvement to an already solid piece of software.
-Manipulation of the fields and their placement as a whole. Maybe support some type of template system. This would also be a major improvement.
Anyways, just giving you some ideas. I love the software as it is, but these would be killer additions. Thanks for the great work.
Re: Huge Request List - Possible Ideas
NoFiX wrote: -Colored text; This would be great for seperating fields in the same field box if the case ever needed to arise. Or maybe even just different fonts, ie. Italics / Bold.... etc.
I do not see what you mean :??:
NoFiX wrote: -Addition of user created fields, with manipulation of their placement as well. I have many different fields I would love to add, also remove, this would be such a huge improvement to an already solid piece of software.
It is planned for version 4 since a long time, but I still haven't start to work on it
