[REL][EN] DVD Empire updated script
deadeye
Post by deadeye »
Updated the script to deal with the site changes plus a couple of small bug fixes.
Please let me know if you have any problems.
Authors=dmitry501,Pavel Uher,Chetan Rao,Deadeye
Title=DVDEmpire.com
Description=Import script for DVD Empire
Site=http://www.dvdempire.com
Language=EN
Version=2.2.0
Requires=4.1.0
Comments=
RequiresMovies=1
MediaType=0|0|0=DVD|1=Blu-ray
PictureType=0|0|0=Large Picture|1=Small Picture
ClearCheckMark=1|0|0=No|1=Yes
[Parameters]
program DVDEmpire;
  StringUtils1;
  LF = #13#10;
  MediaType: string;
  UpdateFile: TStringList;
// ********** Get multiple values from a string **********
// ********** Returns string with comma or linefeed between each item **********
function GetMultiValues(Line : String; StartTag : String; EndTag : String; UseCommaDelimiter : Boolean): String;
    Value     : String;
    Delimiter : String;
  Result := '';
  if (UseCommaDelimiter) then
    Delimiter := ', '
    Delimiter := LF;
  while(true) do
    Value := TextBetween(Line, StartTag, EndTag);
    if Value = '' then
      break
      HTMLDecode(Value);
      HTMLRemoveTags(Value);
      if Pos(Value, Result) = 0 then     // if not a duplicate
        if (Length(Result) > 0) then
          Result := Result + Delimiter;
        Result := Result + Value;
      Line := RemainingText;
// ********** Gets the specific movie info **********
procedure GetMovieInfo(Address: String);
var PageText, Value, TempValue : String;
    hours, mins : Integer;
  PageText := GetPage(Address);
  // URL
  // Picture
  Value := TextBetween(PageText, '<div id="Boxcover"><a href="', '" class="fancy"');
  if GetOption('PictureType') = 1 then
    Value := StringReplace(Value, 'h.jpg', 'm.jpg');
  GetPicture(Value);
  // Original Title
  Value := TextBetween(PageText, '<span itemprop="name">', '</span>');
  HTMLDecode(Value);
  // Media Type
  Value := TextBetween(PageText, 'class="active">', '</a>');
  // Description
  Value := TextBetween(PageText, '<p class="Tagline">', '</div>');
  Value := StringReplace(Value, '</p><p>', LF);
  Value := StringReplace(Value, '®', '®');
  HTMLDecode(Value);
  Value := FullTrim(Value);
  // Length
  Value := Trim(TextBetween(PageText, '<strong>Length</strong>', '<br/>'));
  if Value <> '' then
    hours := StrToInt(Trim(TextBefore(Value, ' hrs', '')),1);
    mins := StrToInt(Trim(TextBetween(Value, 'hrs. ', ' mins')),1);
    Value := IntToStr(hours*60+mins);
    SetField(fieldLength, Value);
  // Rating
  Value := 'Rating: ' + Trim(TextBetween(PageText, '<strong>Rating</strong>', '<br/>'));
  // Year
  Value := Trim(TextBetween(PageText, '<strong>Production Year</strong>', '<br/>'));
  SetField(fieldYear, Value);
  // Number of Discs
  Value := Trim(TextBetween(PageText, '<strong>Number of Discs</strong>', '<br/>'));
  SetField(fieldDisks, Value);
  // Subtitles
  Value := Trim(TextBetween(PageText, '<strong>Subtitles</strong>', '<br/>'));
  SetField(fieldSubtitles, Value);
  // Video format
  Value := Trim(TextBetween(PageText, '<strong>Video</strong>', '<strong>'));
  SetField(fieldVideoFormat, Value);
  // Audio
  TempValue := FullTrim(TextBetween(PageText, '<strong>Audio</strong><br />', '</div>'));
  if TempValue <> '' then
    TempValue := RemoveSpaces(TempValue, true);
    Value := TextBetween(TempValue, ' ', '<br />');
    SetField(fieldAudioFormat, Value);
    // Languages
    Value := '<br />' + TempValue;
    Value := GetMultiValues(Value, '<br />', ' ', true);
  // Actors
  Value := FullTrim(TextBetween(PageText, '<h3>Cast</h3>', '</div>'));
  Value := GetMultiValues(Value, '">', '</a>', false);
  SetField(fieldActors, Value);
  // Producer(s)
  Value := FullTrim(TextBetween(PageText, '<h3>Production</h3>', '</div>'));
  Value := GetMultiValues(Value, '<li>', '</li>', true);
  // Director(s)
  Value := FullTrim(TextBetween(PageText, '<h3>Director</h3>', '</div>'));
  Value := GetMultiValues(Value, '">', '</a>', true);
  // Clear Check Mark
  if GetOption('ClearCheckMark') = 1 then
    SetField(fieldChecked, 'false');
// ********** Gets the movie titles/addresses from the search results page **********
  LineNr, L: Integer;
  MovieAddress, MovieTitle: string;
  LineNr := FindLine('</strong> Matches Found', Page, 0);
  if LineNr > -1 then
    L := StrToInt(StringReplace(Trim(TextBetween(Line, '<strong>', '</strong>')), ',', ''),1);
    If L > 50 then
        PickTreeAdd('First 50 results of ' + IntToStr(L), '');
        L := 50;
        PickTreeAdd(IntToStr(L)+' Matches found', '');
    while L > 0 do
      // Find the line with the film info
      LineNr := FindLine('<p class="title"><a href="', Page, LineNr + 1);
      Line := Trim(Page.GetString(LineNr));
      // find the movie name
      MovieTitle := TextBetween(Line, 'itemprop="name">', '</a>');
      // find the link
      MovieAddress := 'http://www.dvdempire.com' + TextBetween(Line, '<p class="title"><a href="', '" title=');
      // add it to the tree
      HTMLDecode(MovieTitle);
      HTMLRemoveTags(MovieTitle);
      // decrement counter
      L := L - 1;
    GetMovieInfo(Address);
// ********** Begin program **********
    if ShowWarning('Old version of file "Stringutils1.pas" detected: v' + IntToStr(StringUtils1_Version) + LF + 'The script requires at least version 7.' + LF + 'Download and install latest version now ?') = True then
      UpdateFile.Text := GetPage('http://update.antp.be/amc/scripts/StringUtils1.pas');
      UpdateFile.Free;
      ShowInformation('StringUtils1 has been updated. Please restart the DVD Empire script now. Thank you.');
      Exit;
      ShowInformation('You can download latest version of "StringUtils1.pas" using script "update scripts" or via http://update.antp.be/amc/scripts');
      Exit;
  // Check for current AMC version
  if CheckVersion(4,1,0) then
    PickListClear;
    if not Input('Import from DVD Empire', 'Enter the title or the URL of the movie:', MovieName) then
      Exit;
    if Pos('dvdempire.com', MovieName) > 0 then
      AnalyzePage(MovieName)
      MovieName := AnsiLowerCase(MovieName);
      MovieName := StringReplace(MovieName, '’', '');
      MovieName := StringReplace(MovieName, Chr(39), '');
      MovieName := StringReplace(MovieName, ' ', '+');
      MovieName := StringReplace(MovieName, '&', '%26');
      MediaType := 'dvd';
      // Blu-ray
      if GetOption('MediaType')=1 then MediaType := 'blu-ray';
      AnalyzePage('http://www.dvdempire.com/' + MediaType + '/search?exactMatch=' + MovieName + '&q=' + MovieName + '&sort=score&pageSize=50');
    ShowMessage('This script requires a newer version of Ant Movie Catalog (at least version 4.1.0)');
oneacer
Post by oneacer »
This new script you worked on for DVDEmpire.com works like a charm. Thank you again for all your time and effort. If I can assist you with anything, just message me.
Thanks for the update
Sabertooth
Re: [REL][EN] DVD Empire updated script
Post by Sabertooth »
Greetings!
deadeye wrote:Please let me know if you have any problems.
When I attempted to use your script, there is an extra (empty) line at the top of the script that prevented recognition until it was removed. IOW, as posted, the script failed to show up in my scripts list.
oneacer
Post by oneacer »
Only copy from:
program DVDEmpire; .......to........ end.
Then past over existing script, works like a charm. Been using it for years.
deadeye
Post by deadeye »
Sabertooth wrote:there is an extra (empty) line at the top of the script that prevented recognition until it was removed
Sorry about that, it was my misuse of the code tags. Should be fixed now.
I updated it on the server too, as I didn't notice that when I copied the file there.
oneacer wrote:Only copy from:
By doing that you do not have the correct script version indicated (can be useful if you notice problems to be sure that you have the latest one)
And if the script has new options, these would not be added either.
deadeye
latest script version
Post by deadeye »
Update the script to deal with site changes.
Also added the option to show the year of film release or dvd release in the search results.
Title=DVDEmpire.com
Language=EN
Version=2.2.2
Requires=4.1.0
Comments=
RequiresMovies=1
PictureType=1|0|0=Large Picture|1=Small Picture
YearOption=0|0|0=Movie Release Year (if available)|1=DVD Release Year (if available)
[Parameters]
program DVDEmpire;
  StringUtils1;
  LF = #13#10;
  MediaType: string;
    Value     : String;
    Delimiter : String;
  Result := '';
    Delimiter := ', '
    Delimiter := LF;
  while(true) do
    if Value = '' then
      break
      HTMLDecode(Value);
  // URL
  // Picture
  GetPicture(Value);
  // Original Title
  Value := TextBetween(PageText, '<meta itemprop="name" content="', '"');
  HTMLDecode(Value);
  // Media Type
  // Description
  HTMLDecode(Value);
  // Length
  if Value <> '' then
  // Rating
  Value := 'Rating: ' + Trim(TextBetween(PageText, '<span itemprop="contentRating"> ', '</span>'));
  // Year
  // Number of Discs
  // Subtitles
  // Video format
  // Audio
    // Languages
  // Actors
  // Producer(s)
  Value := GetMultiValues(Value, '<span itemprop="name">', '</span>', true);
  // Director(s)
  // Clear Check Mark
  LineNr, L: Integer;
  PageText, MovieText: string;
  MovieAddress, MovieTitle, MovieYear: string;
  L := StrToInt(TextBetween(PageText, '<span class="sub"><strong>', '</strong> Matches Found'),1);
  PageText := RemainingText;
  if L > 0 then
    if L > 50 then
      L := 50;
      // Get the info of one result
      MovieText := TextBetween(PageText, '<div class="container"><span class="rank">', '<p class="cast">');
      // find the link
      MovieAddress := 'http://www.dvdempire.com' + TextBetween(MovieText, '<p class="title"><a href="', '" title=');
      MovieText := RemainingText;
      MovieTitle := TextBetween(MovieText, '"List Page" Label="Title">', '</a>');
      // find the year
      if GetOption('YearOption')=0 then
        MovieYear := FullTrim(TextBetween(MovieText, '- year: ', '</p>'))    // movie release year
        MovieYear := FullTrim(TextBetween(MovieText, '- Released ', LF));    // dvd release year
      if MovieYear <> '' then
        MovieTitle := MovieTitle + ' [' + MovieYear + ']';
      L := L - 1;
    until L = 0;
      UpdateFile.Free;
      Exit;
      Exit;
    PickListClear;
      Exit;
      MovieName := StringReplace(MovieName, ':', '%3A');
      MediaType := 'dvd';
      // Blu-ray
oneacer
Post by oneacer »
Thank You very much.
