Remove trailing Spaces from Title field
Tetsujin
Post by Tetsujin »
Is removing trailing spaces from the Title field something that I could do with RemoveBadChars.ifs
I imported Titles without checking for trailing spaces first.
I am not sure if it does, but you could probably just use a simple script like this:
Program NewScript;
  s: string;
  s := GetField(fieldOriginalTitle);
  s := Trim(s);
  SetField(fieldOriginalTitle, s);
(note that it will also remove leading spaces if there are any, but I guess it is not a problem)
