Templates
nofix
Templates
Post by nofix »
Will it be possible to change the active appearance of the actual app?
Like say, for most of my movies, I like to view the plot and the comments, so a lot of the information that is posted isn't really needed in my case. So what I'm asking more or less if you plan on allowing altering the textboxes in the main app?
Sure, in version 4 it should be possible to customize fields, adding/removing fields, moving fields, etc.
I do not know when it will be released, but it is planned ;)
Damn dude, you rock.
Any Idea when Ver 4 will be out???
I love this program so much I was thinking about putting it on a 3.5 " disk
and Taking it to bed with me!!!
But If I had to Pick Only one thing to change it would be:
"customize fields, adding/removing fields, moving fields"
Thanks for all the hard work on this program!!
Re: Any Idea when Ver 4 will be out???
Anonymous wrote:Any Idea when Ver 4 will be out???
when it will be ready :p
I only started to work on the window to customize fields, but since lots of things will have to be rewritten to support these customizable fields, it will take lots of time.
And for the moment I do not really use lots of time for AMC, since when I am not at work or sleeping I also have to play Simcity 4 and to work on Ant Renamer.
