What script to fetch high-res poster/cover?
rs232
Post by rs232 »
HI all,
does anybody have a good suggestion on what script to use to be able to fetch a decent size cover for the movie (e.g. poster).
Anything more than 1000 pixels would do (e.g. imdb images are not good enough).
Appreciated!
Try Impawards if the script still works, as that site is probably one of those offering the best poster pictures (at least for US movies).
Post by soulsnake »
If you want big pictures in your catalog, I recommand you to use copied pictures instead of stored pictures.
All pictures stored in catalog are loaded in memory during catalog loading (not copied/external pictures).
So if you have big pictures, you will use a lot of memory ;).
rs232
Post by rs232 »
I knew that thanks, but what script to use to get the pictures?
Imp Awards, as I suggested (I dot not know if the script still works, but you could try it)
