Importing movies
Apphoard
Importing movies
Post by Apphoard »
I imported all of my movies and it went good. But the few I messed up on and re-imported go into another directory I guess you would say. How do I get later imports to add onto the others and not start over?
Thanks for your help!
Apphoard
Post by Apphoard »
I figured it out. :)
