Multiple String Replacement
LiquidCode
Post by LiquidCode »
Hello,
i have a question concerning the Multiple String Replacement and i hope someone of you guys may help me.
I have entered a list of stings and i saved it with name "xyz".
But how do i can backup this saved list for example to transfer it to another computer? I do not find the list named "xyz".
And how do i import the List?
It would be very kind of you, if someone can help me.
Liquid
These lists are stored in the preferences file along all other settings, in Renamer.xml
That file is located in the program's folder, i.e. "C:\Program Files\Ant Renamer" by default, or "Program Files (x86)" depending on your system.
However if you use Windows Vista, 7 or 8, you may have to get the file from the Virtual Store, i.e. "C:\Users\<your name>\AppData\Local\VirtualStore\Program Files (x86)\Ant Renamer".
You can access that folder easily by typing %appdata% in Windows Explorer address bar and then going one folder up to go back to AppData (as that keyword leads to AppData\Roaming)
LiquidCode
Hi antp,
thank you for your quick support.
This was exactly what i needed!
:grinking:
