ANT Catalog on the web
boubouni
Post by boubouni »
I just created a php site which uses the XML file of the catalog. The site also allows minor editing of the XML data. The code is available upon request. Have a look at films.boubouni.com.
xxxxl
Post by xxxxl »
Great job !
Can you send me the code ?
xxxxl.
quakie
Post by quakie »
excellent work !
Can you send me the code, please ?
emKa
Post by emKa »
super, super, super!
Can I get the code, please?
mfournet
Post by mfournet »
Super !
Please Get code
kgytopi
get the code
Post by kgytopi »
Super, i like it!
Topi
monnezza
wow!
Post by monnezza »
this is exactly what I was waiting for!!!!!!
Can you send me the code, please?
Did someone get the code at the end? I could put it on the server if the author wants.
moucho
Post by moucho »
Great!
Please send me the code
Cheers!
I see that he didn't put the link in his post in the end :??:
As he sent it to me, here is it:
https://forum.antp.be/users/boubouni/
Wonderful, but I'd like a little help:
- Does it can be used locally in my PC?
I tried exporting my catalog XML in the same folder containing the program but, opening it with firefox I obtain:
Where is my mistake?
:hum: :ha:
If it is in PHP, you need a web server running PHP, even if it is for local use. Do you have one on your computer?
For local use there are all integrated solutions like EasyPHP.
uh oh... :fire:
done, now it's allright :D
thanks
Smiehu
Error with xml files
Post by Smiehu »
I have a problem with this php site.
I got a error: XML error at line 1 column 42
even on the test.xml.
Mayby problem is in my webserver (on Synology DS212) with PHP 5.3?
Best regards,
Smiehu
If you open the .xml file directly in the browser, so you also get an error?
What is the contents of the line 1, what's a the column 42 ?
Smiehu
Post by Smiehu »
It working now.
I had to change encoding to utf-8.
It is possible to view movie list without covers? Only simple list?
monnezza
Post by monnezza »
I have the same problem, but I can't figure out where I need to change encoding to utf-8.... Can you give me some advice? :grinking:
To encode the XML file to UTF8, you can for example open it with notepad and save it as UTF8 (in the save as window, there is a field to chose the encoding).
You'll also have to edit the encoding in the header, specifying "utf-8" instead of "windows-1252" or "iso-8859-1" for example.
monnezza
Post by monnezza »
Thank you very much for the fast reply!
Now it works fine, but.... ant movie catalog can't open anymore the xml file so generated.
It must be opened through notepad, saved in "iso" and then reopened in amc. Quite annoying.
Same for you I guess....
Yes, AMC does not support UTF8.
