When I try to use IMDB script it returns me an error
HTTP/1.1 404 Not Found
How can I fix it?
IMDB script doesn't work
Raoul_Volfoni
... Maybe with an update of the script ?al0203 wrote:When I try to use IMDB script it returns me an error
How can I fix it?
3.79 is the last version, if you don't have it, the easiest way to update any script is to use the [ UPDATE SCRIPTS ] script.
Just to make sure the script appear in the list, ensure you have check the "[ UPDATE SCRIPTS ]" in your "Language Filter" section of the scripting window ...
If you have more questions about the imdb script, go check the scripts section of this forum and look about imdb topics.
By the way, there is a more recent version of the AMC program.
4.1.2.3 available here. If you upgrade, think to save your database in a save place.
