Duplicates movies
al0203
Duplicates movies
Is there any function to easily find the duplicates movies that you have in your catalog.
al0203
Raoul_Volfoni
If it's about a missing or wrong version of file ... then the "Find Duplicate" script needs the "StringUtils1.pas" file in order to work properly. You can find this file here too. You have to put it in the "Scripts" directory of AMC
If it's something else, tell us what is the error message and what version of AMC you are using.
The "Find Duplicate.ifs" script is available here. But there is just only one version from 2005.al0203 wrote:Can you copy here the script?
What error message ?al0203 wrote:It gives me an error message.
al0203
Error in Script in "FINDDUP": in the line 29Raoul_Volfoni wrote:Hi,The "Find Duplicate.ifs" script is available here. But there is just only one version from 2005.al0203 wrote:Can you copy here the script?
This is the complete script
program FindDup;
StringUtils1;
MovList: TStringList;
DupList: TStringList;
CurTitle: string;
ResultPath: string;
if StringUtils1_Version < 3 then
ShowMessage('File "stringutils1.pas" is too old, please download a new version of it');
Error;
if ResultPath = '' then
ResultPath := 'c:\duplicates.txt';
Input('Find Duplicates', 'Store results to:', ResultPath);
if MovList = nil then
MovList := TStringList.Create;
if DupList = nil then
DupList := TStringList.Create;
case GetOption('TitleToUse') of
1: CurTitle := GetField(fieldOriginalTitle);
2: CurTitle := GetField(fieldTranslatedTitle);
3: CurTitle := GetField(fieldOriginalTitle) + ' | ' + GetField(fieldTranslatedTitle);
Error; // wrong option
if GetOption('IgnoreCase') = 1 then
CurTitle := AnsiLowerCase(CurTitle);
if FindFullLine(CurTitle, MovList, 0) <> -1 then
DupList.Add(CurTitle)
MovList.Add(CurTitle);
DupList.SaveToFile(ResultPath);
The line 29 said Error; // wrong option
I think you don't copy the script file in AMC script folder but just copy/paste code no ?
This script uses options (GetOption function) so you can not just copy/paste the script code in script editor, this will not work.
You have to copy the script file in AMC script folder and use this one (it will be added to script list automatically when you will open "Tools -> Scripting" window).
al0203
It was very estrange because the script file is in the hidden folder with the rest of the scripts, but it doesn't appear in the AMC. So what I did is to edit another existing string, empty it and copy inside it what I pasted in the previous post.soulsnake wrote:Hi,
It should appear in Tools->Scripting (but not from the other script menu, as that one is for scripts importing info from sites)al0203 wrote: It was very estrange because the script file is in the hidden folder with the rest of the scripts, but it doesn't appear in the AMC. So what I did is to edit another existing string, empty it and copy inside it what I pasted in the previous post.
Raoul_Volfoni
al0203
My version is 4.1.0.2soulsnake wrote:What version of AMC do you use ?
Is it installed or portable version ?
I think you didn't copy the script in the good AMC script folder that why the script doesn't appear in "Tools -> Scripting" window.
I used the filter and it appear and it works.
Thank you everybody
