CheckBox... ReadOnly
YoungBoy
Post by YoungBoy »
I would like that some fields were read-only because I modify them using a script only.
I can with all ... but not with checkbox of the list movie.
How can I do?
Thank in advance.
Regards
for all the fields I do so
          inherited EOriginalTitle: TEdit
          Width = 1339
          Font.Style = [fsBold]
          ParentFont = False
          ReadOnly = True //My Modify
For the checkbox you could try Disabled=true
YoungBoy
Post by YoungBoy »
I solved (InvertClickCheckBoxes = True)
Thank
