Sub Directories
bpeddicord
Sub Directories
Post by bpeddicord »
Does anyone know how to setup a file like system for the listing of movies.
The main title would be: STAR WARS
the sub directories would be: The Phantom Menace and attack of the Clones.
Example:
  • STAR WARS
    The Phantom Menace
    Attack of the Clones
This is how i would like to do all of my different series.
Thanks ahead of time, Bob :)
You mean organizing the movies in AMC, or organizing the files on your disk? For the second one, I do not really see what you ask :??:
For the first one, you could use the "Group by" function and the various options related to it: enter "Starwars" as the media label or a custom field that you add, and then group on that field.
bpeddicord
Organizing in AMC.
Have tried the group and options plus adding extra fields. The group is good
if you are only looking for certain ones, but as listing everything and having
it list out as described above have not figured it out.
You mean that you want movies outside any group?
In version 3.5 there was an option to not put in group movies which didn't had an info for regrouping, but in version 4 soulsnake removed that option for technical reason. I do not know if he plans to fix that later or if it is really not possible.
