It seems the IMDB script is not working again. I was using it last night and today i just get errors when trying to run it.
Lost of not found even if it's a well known movie and even if I manually got the IMDB URL and set the script to run from there. Some times you get a "Socket Error # 10061" and "not found" errors
Don't know if anyone has any idea how to fix this...
IMDB Script version 3.79
IMDB script issues 01/02/2013
I tested a few older and newer movies and did not have problems. Please try again, maybe it was an IMDB server issue. If you still have problems these might be related to some countries only or caused by specific script settings. You could make a screenshot of scripting window that shows script options on the right side so someone can confirm.
Droppo
