Request: Save pictures in DB file.
nofix
Post by nofix »
How about saving the pictures in the db file? It makes it really hard to manage the pictures, when they're all saved in the AMC directory.
Actually there are saved in the .amc file, except when using the IMDB large pic script from previous week that had a problem.
And when assigning manually a picture to a movie, you have the choice to store it in the catalog file or to simply link the real file.
Is it possible to have the big pics saved in the file in any way?
yes, if you use the IMDB large pic script, just modify the lines "GetPicture(Value, True);" in this script : replace True by False.
You can also redownload the .zip file containing the scripts.
For the pictures that are already stored outsite the catalog, you can simply (for each movie), click on the "Import a picture" icon and select the picture.
