How to get English Original title when using IMDB script?
chatmaster
Post by chatmaster »
When I import information using the IMDB script AMC keeps translating the Original Title probably since I log from another country, as though it senses the IP.
I tried in the preferences, restarting AMC, but it just doesn't work as it did before the last script update.
thanks
AMC does not translate anything: it is IMDb which sends different results depending on the IP. They probably made a change recently, so the script would have to be properly updated to reflect that (I just did a quick fix as the search was not working), but it is not easy to do since the page sent depends on the IP, sometimes the original title is used as main title, sometimes not.
