Imdb issues
Odd-Laws
Imdb issues
Post by Odd-Laws »
Hello I'm Odd-Laws and new.
I am trying to use AMC, but having trouble with connecting imdb.
I have installed the newest amc, updated the script but still getting the anoying message "404 not found bla bla bla"
I am a noob concerning scripts but i think i did it right.
I changed this (line92)
Value := TextBetween(PageText, '.</td><td valign="top">', '</a>');
into this manually
Value := TextBetween(PageText, '<td class="primary_photo">', '<img src');
English is not my native language so i hope you understand the item.
1) What am i doing wrong?
2) how can i import .ifs best?
Thanks in advance
Odd
Are you using the version 3.75 of the script? (it is written at the bottom of the script window)
If yes, for which movie do you have problems?
To me that version works fine.
Odd-Laws
Post by Odd-Laws »
Thank you for your reaction antp,
Yes i am using version 3.75 of the script and what ever movie i try, i constantly get that :angry: :angry: message.
Even uninstalled and re-installed all and stil it doesn't work.
Now it seems to work fine with moviemeter.nl, but that site misses a lot of movies....
Odd
Can you make a screenshot of the options on the right of the script list? Maybe an option that you enabled (but I didn't) does not work anymore.
Odd-Laws
Post by Odd-Laws »
I will try it... it's a bit large
Thank you! Odd
And what about the few more options after "MultipleValuesLangu..."?
As for the visible ones, I have set the same and for me it works (e.g. with the movie "Looper")
Another possibility is that IMDB delivers you a slightly different page because you are in NL and I am in Belgium...
Odd-Laws
Post by Odd-Laws »
I tried and changed several settings, but still that :mad: error message.
I quit for a while trying.
I'll do a clean install from my windows soon anyway so i guess that it will be working then.
Thank you for your support and keep on the good work
Odd
