some bugs in 3.4.2
an0rmal
some bugs in 3.4.2
Post by an0rmal »
hi all,
3.4.1 worked perfect for me :) but i updated to 3.4.2 and noticed some bugs??
first it seems that the duration of the movies has changed for every movie ??
second, the movie images are not saved inside the catalog but in the AMC directory ???
is 3.4.2 beta? has been tested ???
thanks for your time guys!
bye!
It is a bug in the IMDB large pic script, not in the program itself
Actually that's not me that update this script.
I updated the script yesterday to correct this problem, so you can re-download the script, or modify yourself the script : in all the GetPicture(Value, True); replace True by False.
For the length, what do you mean ? it did not change for all movies, but maybe that something changed in newly imported movies.
I'll have to check that...
an0rmal
still bugs
Post by an0rmal »
hi!
thanks for the imdb tip,
what i got errors are the movie long in minutes, i guess all are bad, if you want i can check them so we can guess what really happened
am i the one and only with this error?
regards
When I make few tests movie lengths are correct.. can you give me an example of a movie on imdb that is wrongly imported ?
hi again,
let me explain, AMC imports correctly the movie length from IMDB,
but what worked wrong was the importing from old version,
i just put the new version files over the old ones, lunch AMC and then all my movies had bad lengths
the new ones i am importing from IMDB are ok
some examples:
Title - correct length - bad length
Todo sobre mi madre - 101 - 197
Leaving las Vegas - 111 - 171
Citizen Kane - 119 - 233
etc ...
what can i do?
must i re-import all my movies' info??
i have a lot !! :(
regards!!!
Are you sure that you do not import file information after script info ?
Because if you did not disable it, it imports file info. But since it has to support multiple files, it adds length instead of replacing it.
