renumbering
J
renumbering
Post by J »
hi,
I´m looking for a way to renumber all the movies in a catalog at once to a selectable start number, e.g. change number 1..400 to 1000..1400
Or much better to renumber only the selected/marked movies with a selectable start number.
Is there a way to set the start numbering when importing a catalog?
Thanks.
J.
