The pocket version of AMC allows you to have your data base an android phone or tablet.
Is it either possible now or sometime in the near future to add, delete or change data on these android devices?
Thanks in advance
Edit your data base on android device?
KoolPal
Re: Edit your data base on android device?
Would love this feature too!Confused wrote:The pocket version of AMC allows you to have your data base an android phone or tablet.
Thanks in advance
elman
KoolPal
Elman,elman wrote:Sorry guys, but I intend to keep Pocket AMC Reader strictly a reader. It would be way too much work and my free time is limited.![]()
But Pocket AMC Reader is open source and anyone willing to undertake the task can PM me and ask for sources code.
Elman
First of all, thank you very much for this amazing app for android.
A small request. Can this be explored?
For e.g.
1. Check a movie on app
2. View movie and make an observation.
3. Make SOME update for that movie in Android app and save
4. Later run some filter in app to find these updates on app
5. Go back to AMC and update manually. No sync between app and AMC expected.
In summary, can you help with JUST ONE field for user comment or anything ON ANDROID APP and then provide an option to find all such entries on the app with the comments visible?
Thanks a ton if this could be accommodated.
elman
You're very welcome.KoolPal wrote:First of all, thank you very much for this amazing app for android.
Feature exactly like this is actually in my to do list. So it will come some timeKoolPal wrote:In summary, can you help with JUST ONE field for user comment or anything ON ANDROID APP and then provide an option to find all such entries on the app with the comments visible?
KoolPal
