None of the scripts I have are working!!
fellowmelad
Post by fellowmelad »
Hi all,
I must be doing something wrong, but I don't know what...
I have updated the scripts (using F6 and then choosing to update scripts), but I don't get any useful information running any of the scripts. Not on IMDB, not on Allmovie, not on Amazon.
Please help!
Best regards,
Fellowmelade
What version of the program do you use?
What version of the imdb script do you have, for example?
If problems appear with all scripts, there may be some proxy/firewall/... software which filter pages and alter their contents
fellowmelad
Hi antp,
Thanks for you reply!
Strange! I just installed the latest version from http://www.antp.be/software/moviecatalog on another PC and ran it. Worked fine with All Movie Guide! Haven't tried the others yet, but it seems thee must be something wrong on my laptop. Will check tonight when I am home.
fellowmelad
scripts are working!!
Hi antp,
I just uninstalled the version on my laptop at home, and installed the latest version, and all works fine now!
Best regards,
fellowmelad
