Set default after script is run to "Save All"
comeek
Post by comeek »
I'd like to be able to skip the results page by setting a default to "Save All" every time I run a script. Also like to skip the Confirmation pop-up.
Post by soulsnake »
You just have to uncheck "Show results window" in "Execution options" at right of script window.
ADELIAlong
Post by ADELIAlong »
soulsnake wrote:Hi,
thanks :) :)
