Update movie file catalog
kartola
Post by kartola »
Hi, i imported the movie from my movie folder.
Then I use script to add movie informations.
If I add some files, is possible to update the movie list with only the new movies?
It doesn't recognize the old imported movies and it imported like new ones...
Post by soulsnake »
Do you see this post ?
viewtopic.php?t=5148
And this post ?
viewtopic.php?t=5111
