Determining file vs directory before renaming
frdkli1348
Post by frdkli1348 »
I knew that I can choose to add file or directory or both in the options.
But frequently switching between these options is a bit clumsy.
Would it be better to add all objects to the list,
but have a simpler UI option to select what type of target to rename?
And if possible, include that option in the antrenamer xml script too?
So that loading a particular script will only work on file or directory or both.
Thanks.
Antrenamer is great!
In the way it works it would be not so easy to modify I think.
How do you add the items to the list? By drag & drop from the Explorer, or using the "Add Folders" button?
