Hi there
Today I used AMC again to add some new DVD to me collection.
But, my favorit script does not what I expexted it to do!
WORLD-OF-VIDEO does not get any results anymore !!!
Can anybody help?
I already ran the script update and restarted AMC but didn't fix the problem.
Hope to hear from u ...
world-of-video not working
kgytopi
Re: world-of-video not working
ralfkausk wrote:Hi there
Can anybody help?
Works perfectly at me (try with KOJAK and AMC version 3.5.1)
ralfkausk
Ich benutze:
MovieCatalog.exe: Version 3.5.1.2 (erstellt am 01.02.2009 18:15:52)
AMCExchange.dll: Version 1.1.0.1 (erstellt am 22.09.2007 10:47:56)
AMCReport.exe: Version 1.0.2.2 (erstellt am 15.01.2005 16:13:58)
MediaInfo.dll: Version 0.7.26 (erstellt am 18.12.2009 11:12:44)
Es funktioniert aber leider auch nicht mit KOJAK
Hast Du noch 'ne Idee?
What exactly is the problem ? No results at all, only headlines on results list, or something else ?
On a short test using Kojak it worked for "Treffer im Titel" while reading "Treffer im Originaltitel" and adding FSK on the list failed, this has just been fixed and will be available soon - I just would like to know if there are more problems so that fixes could be included with the update.
Btw the most recent version of the script is 3.0.1, you should verify that from the status frame below the list of scripts.
ralfkausk
The problem is: nothing is found.
The script starts, connects, loads something down ...
but the result is:
Leihmovies = 0
Kaufmovies = 0
The script is version: 2.0.3 - 04.04.2009
This is maybe the problem.
But I used the update function and thought it made an update to all scripts.
Right now I started the update script again.
It shows a lot of out dated scripts but neither in "UPDATED" or in ADDITIONAL" scripts is an world of video update.
Would u pls so kind and let me know how to get the latest version.
Thx in advance
Ralf
but the result is:
Leihmovies = 0
Kaufmovies = 0
Thx in advance
Ralf
Raoul_Volfoni
ralfkausk
