Can't connect catalog to new tablet
Confused
Post by Confused »
I tried a few months back to transfer a catalog to my android phone but didn't have any success. Now I'm back with any android tablet Samsung Tab2 10.1 which should be idea for displaying the database.
Before I wasted too much time in creating a large database I created a new one with only 3 entries & saved it. I then exported it as a XML file & saved it onto the desktop. I ended up 4 files 3 of which were the jpegs thumbnails for each picture. In the absence of any other instructions I created a new folder & put the 4 files into the folder. I dragged this folder onto my Tablet.
I opened the app on the tablet & went searching for the patch to my catalog & clicked it. The app didn't import my catalog.
I took the 4 files out of the folder with the intent of connecting the app to the main catalog file but I could not find the correct file to connect to.
Where did I go wrong?
Thanks in advance
Is your message related to the AMC reader from viewtopic.php?t=4717 ? If so you should rather post there (unfortunately I can't help you about that program)
