"$$TOTALDISKS" param would be helpful!
Shurik76
Post by Shurik76 »
"$$TOTALDISKS" parameter would be helpful to show the total number of disks for the entire collection.
why not, but I do not think that there will be more updates of current 3.x version.
Version 4 will require a really new system for the templates since the fields will be customizable, I guess I'll have things such as "Sum(fieldname)" where you can get the sum of the values of a field through all movies.
