Hi everybody,
I'd like to fill, in the whole database, a currently empty field with a value (the same for all films). I tried the updateFields script, but I couldn't get it to do what I want...
Here is how it goes on:
- I choose "replace a field"
- In the list of fields that appears, I highlight the field I want to fill
- I answer yes to the message "you will replace the field contents"
- I enter the new value I hope to obtain
- I click OK, the window closes and... nothing happens!
I did update the script.
I also tried different filter options, but it still doesn't change anything.
Your help would be greatly appreciated...
Help needed to use UpdateFields script
Malbec
Here is a screen dump of the config I use:
http://www.flickr.com/x/t/0095009/photos/87050321@N04
Malbec
Malbec
