Feature request: Date taken sorting
AKazak
Post by AKazak »
Dear users,
Recently I had to rename a set of JPGs, but sorted by Date taken instead of Date created or Date modified. As far as I understood, however, in its current version (2.10.0) Ant Renamer cannot do this.
Therefore it would be nice to add the Date created similar to that of Explorer of Windows 7.
What do you think on this idea?
You can still rename them by adding the date in front of the name using the Exif fonction, then sort by name.
AKazak
Post by AKazak »
OK.
I've got you point :grinking:
