I have the latest Ant Movie catalog (4.1.1.2) on my Win XP SP2. I've just updated from v3.5.1
I have a problem with fields resize. If I go with my mouse on the field N. (Number) and I want to enlarge it because I can't see the number (example: the number is 166501 but I only see 166..) I can't do it. In previous versions I was able to enlarge it. With 4.1.1.2 I can only resize the windows, that is if I want a smaller picture window I can reduce it.
Unresizable fields
Maybe I don't understand well but this has never been possible in old version 3.5.1.In previous versions I was able to enlarge it.
You talk about column "Nr" in movie list (in list mode and not in grid mode), right ?
Nevermind, I added the possiblity to resize this column for the next release
Here a screenshot. Maybe in previous version I modified an entry in an ini file to resize that column, I'm not sure, but I'm sure I could see the entire value of number field.
In the image below I signed the column I can't resize
Uploaded with ImageShack.us
Thank you man
Thank you man
