XML Problem
I-Catch
XML Problem
Post by I-Catch »
hi
today i was writing a script for the android and iphone app http://www.netwalkapps.com/app/movielicious-android
and because the app has an import funktion i want to write a script to export my data (here are the specifications http://www.netwalkapps.com/movies-xml-format )
here is the which i wrote:
program MovieliciousExporter;
  xmldata,curitem:string;
  xml:TJvSimpleXml;
  savepath = 'Z:\media\Daten_2TB\';
procedure getdata;
  Xml.Root.Items.Add('movie');
  Xml.root.items.getitemnamed('movie').items.add('MovieID');
  Xml.root.items.getitemnamed('movie').items.add('title');
  Xml.root.items.getitemnamed('movie').items.add('media');
  Xml.root.items.getitemnamed('movie').items.add('genre');
  Xml.root.items.getitemnamed('movie').items.add('year');
  Xml.root.items.getitemnamed('movie').items.add('mpaa');
  Xml.root.items.getitemnamed('movie').items.getitemnamed('MovieID').value:=getfield(fieldnumber);
  Xml.root.items.getitemnamed('movie').items.getitemnamed('title').value:=getfield(fieldtranslatedtitle);
  Xml.root.items.getitemnamed('movie').items.getitemnamed('media').value:=getfield(fieldnumber);
  Xml.root.items.getitemnamed('movie').items.getitemnamed('genre').value:=getfield(fieldCategory);
  Xml.root.items.getitemnamed('movie').items.getitemnamed('year').value:=getfield(fieldyear);
  Xml.root.items.getitemnamed('movie').items.getitemnamed('mpaa').value:=getcustomfield('fsk');
  xmldata:=xml.savetostring;
  xml:= TJvSimpleXml.create(nil);
  //xml2:=
  if xml.root.name='' then xml.root.name:= 'XMM_Movie_Database';
  //Xml.Root.Items.Add('movie')
   //a:=Xml.Root.GetChildIndex(Xml.root.items.getitemnamed('movie'));
    //xmldata:=xml.savetostring;
 getdata;
  curitem:=curitem+xmldata;
  showmessage(curitem);
the problem is now that it worked for one movie but if i selced more than it lokk like
<?xml version="1.0" encoding="iso-8859-1"?>
<XMM_Movie_Database>
 <movie>
  <MovieID>1</MovieID>
  <title>(Traum)Job gesucht</title>
  <media>1</media>
  <genre>Komödie, Liebe/Romantik</genre>
  <year>2009</year>
  <mpaa>o.A.</mpaa>
 </movie>
</XMM_Movie_Database>
 <movie>
  <MovieID>2</MovieID>
  <title>2 Fast 2 Furious</title>
  <media>2</media>
  <genre>Action</genre>
  <year>2003</year>
  <mpaa>ab 16 Jahren</mpaa>
 </movie>
so the root node is double
i hope someone can help me and know what i mean
The problem is that you recreate the XML object each time: you should create it only if it is equal to nil.
So it will be kept between movies.
Each time instead of curitem:=curitem+xmldata; you can simply keep "xmldata" which should grow by itself if you do not recreate the xml object.
I guess that instead of show it the next step would be writing it to a file.
The downside is that the file will be written at each movie, but it is not a big problem (it will not affect the result).
Post by soulsnake »
This code bellow should work in AMC 4.1.0.2 or more.
program MovieliciousExport;
  xml: TJvSimpleXml;
  savepath = 'Z:\media\Daten_2TB\MovieliciousExport.xml';
  //savepath = 'C:\Users\snake\Desktop\MovieliciousExport.xml';
procedure AddMovieData;
  eMovie: TJvSimpleXmlElem;
  xml.Root.Items.Add('movie');
  eMovie := xml.Root.Items.GetItemNamed('movie');
  eMovie.Items.Add('MovieID');
  eMovie.Items.GetItemNamed('MovieID').value := GetField(fieldnumber);
  eMovie.Items.Add('title');
  eMovie.Items.GetItemNamed('title').value := GetField(fieldtranslatedtitle);
  eMovie.Items.Add('media');
  eMovie.Items.GetItemNamed('media').value := GetField(fieldnumber);
  eMovie.Items.Add('genre');
  eMovie.Items.GetItemNamed('genre').value := GetField(fieldCategory);
  eMovie.Items.Add('year');
  eMovie.Items.GetItemNamed('year').value := GetField(fieldyear);
  eMovie.Items.Add('mpaa');
  eMovie.Items.GetItemNamed('mpaa').value := GetCustomField('fsk');
  if GetIteration = 0 then // First iteration
  begin // We prepare XML
    xml := TJvSimpleXml.create(nil);
    xml.Root.Name := 'XMM_Movie_Database';
  // We add movie data
  AddMovieData;
  if GetIteration = GetIterationCount - 1 then // Last iteration
  begin // We save XML to file and we close it
    xml.SaveToFile(savepath)
    xml.Free
PS: I found a bug.
The code bellow should work but it doesn't.
It returns a type mismatch error on eMovie and eField.
Why ? In program source code, the class TJvSimpleXmlElemClassic is declared but after "Add" function, that why the error occurs.
This problem will be fixed in next update 4.1.1 and the code bellow will work correctly.
  xml: TJvSimpleXml;
  savepath = 'Z:\media\Daten_2TB\MovieliciousExport2.xml';
  //savepath = 'C:\Users\snake\Desktop\MovieliciousExport2.xml';
  eMovie, eField: TJvSimpleXmlElemClassic; // or TJvSimpleXmlElem
  eMovie := xml.Root.Items.Add('movie'); // Doesn't work
  eField := eMovie.Items.Add('MovieID'); // Doesn't work
  eField.value := GetField(fieldnumber);
  eField := eMovie.Items.Add('title');
  eField.value := GetField(fieldtranslatedtitle);
  eField := eMovie.Items.Add('media');
  eField := eMovie.Items.Add('genre');
  eField.value := GetField(fieldCategory);
  eField := eMovie.Items.Add('year');
  eField.value := GetField(fieldyear);
  eField := eMovie.Items.Add('mpaa');
  eField.value := GetCustomField('fsk');
    xml := TJvSimpleXml.Create(nil);
  AddMovieData;
    xml.Free
I-Catch
Post by I-Catch »
hi
thanks soulsnake that worked for me but is there an option to change the encoding to utf-8 and not iso-8859-1
mfg
ps i think there is a bug in the AddNewMovieToQueue. becuase when i use it adds lots off new movie instead of one.
Post by soulsnake »
No, but you can open the generated file with notepad++ or other editor to convert file into utf-8.
I think it is not a bug but a bad use of this function.
This function have to be called very carefully.
You have to understand you execute the same code for each selected movie.
So if you put the function like this without any test, you produce an infinite loop. Why ? You call this function for each selected movie + the new movies you added with this function + new movies added by new movies + ... so you produce an infinite loop.
You have to use global variables and script functions to do some tests.
Here is a simple example how to use this function.
You have to select at least one movie in list to run this code :
program AddNewMovies;
  nbNewMovies = 100; // Number of new movies to add
  newMovieStart: Integer;
    newMovieStart := GetIterationCount;
    for i := 0 to nbNewMovies - 1 do
      AddNewMovieToQueue;
  else if GetIteration >= newMovieStart then // One of new movies added
    i := GetIteration - newMovieStart + 1;
    // Set title of new movie
    SetField(fieldOriginalTitle, 'Movie N°' + IntToStr(i));
PS: I see a little bug, movie number is not correct.
It is the max(numbers) instead of max(numbers) + 1.
This will be fixed in next update.
For the UTF8 you could encode all texts using UTF8Encode, but I am not sure it is possible to set the character set info in the file header
I-Catch
Post by I-Catch »
thank i got it working
here is the script if someone need it (maybe you have custumize it to your customfields)
SoulSnakeUtils ;
  xml: TJvSimpleXml;
  exportxml,batch:tstringlist;
  convert,actorsvalue:string;
  savepath = 'Z:\media\Daten_2TB\movies\';
function ActorsToXml(actors: string): string;
  lstActor: TStringList;
  iActor,startpos: Integer;
  sActor,name:  string;
  lstActor := TStringList.Create;
  lstActor.Text := stringreplace(actors,', ',#13#10);
  for iActor := 0 to lstActor.Count - iActor do
    startpos:= pos(' (',lstActor.GetString(iActor));
    sActor := ', ' + name ;
    if lstActor.GetString(iActor) <> #13#10 then lstActor.SetString(iActor, sActor);
  Result := lstActor.Text;
  lstActor.Free;
  seen:string;
  xml.Root.Items.Add('Movie');
  eMovie := xml.Root.Items.GetItemNamed('Movie');
  eMovie.Items.Add('Title');
  eMovie.Items.GetItemNamed('Title').value := GetField(fieldtranslatedtitle);
  eMovie.Items.Add('Media');
  eMovie.Items.GetItemNamed('Media').value := GetField(fieldVideoFormat);
  eMovie.Items.Add('Genres');
  eMovie.Items.GetItemNamed('Genres').value := GetField(fieldCategory);
  eMovie.Items.Add('Year');
  eMovie.Items.GetItemNamed('Year').value := GetField(fieldyear);
  eMovie.Items.Add('MPAA');
  eMovie.Items.GetItemNamed('MPAA').value := GetCustomField('fsk');
  eMovie.Items.Add('Country');
  eMovie.Items.GetItemNamed('Country').value := GetField(fieldcountry);
  eMovie.Items.Add('Length');
  eMovie.Items.GetItemNamed('Length').value := GetField(fieldLength);
  eMovie.Items.Add('Plot');
  eMovie.Items.GetItemNamed('Plot').value :=GetField(fieldDescription);
  eMovie.Items.Add('URL');
  eMovie.Items.GetItemNamed('URL').value := GetField(fieldurl);
  eMovie.Items.Add('Director');
  eMovie.Items.GetItemNamed('Director').value := GetField(fielddirector);
  eMovie.Items.Add('Rating');
  eMovie.Items.GetItemNamed('Rating').value := GetField(fieldrating);
  eMovie.Items.Add('Notes');
  eMovie.Items.GetItemNamed('Notes').value := GetField(fieldcomments);
  eMovie.Items.Add('Position');
  eMovie.Items.GetItemNamed('Position').value := GetcustomField('pfad');
  exportpicture(savepath + '12temp34\' + GetField(fieldnumber)+PictureExt);
  eMovie.Items.Add('Cover');
  eMovie.Items.GetItemNamed('Cover').value := GetField(fieldnumber)+PictureExt;
  eMovie.Items.Add('Actors');
  actorsvalue:=actorstoxml(getfield(fieldactors));
  delete(actorsvalue,1,2)
  eMovie.Items.GetItemNamed('Actors').value := actorsvalue;
  eMovie.Items.Add('Loaned');
  eMovie.Items.GetItemNamed('Loaned').value := GetField(fieldBorrower);
  //eMovie.Items.Add('LoanedDate');
  //eMovie.Items.GetItemNamed('LoanedDate').value := GetField();
  //eMovie.Items.Add('PersonalRating');
  //eMovie.Items.GetItemNamed('PersonalRating').value := GetcustomField('Prating');
  eMovie.Items.Add('PurchaseDate');
  eMovie.Items.GetItemNamed('PurchaseDate').value := GetField(fieldDate);
  eMovie.Items.Add('Seen');
  eMovie.Items.GetItemNamed('Seen').value := GetcustomField('gesehen');
    batch:=tstringlist.create;
    batch.text:='mkdir ' + savepath + '12temp34';
    batch.savetofile(dirapp + 'start.bat');
    Launch(dirapp + 'start.bat','');
  AddMovieData;
    convert:=xml.savetostring;
    convert:=stringreplace(convert,'iso-8859-1','utf-8');
    convert:=utf8encode(convert);
    //showmessage(convert);
    exportxml:=tstringlist.create;
    exportxml.text:=convert;
    exportxml.savetofile(savepath+'12temp34\export.xml');
    //xml.loadfromstring(convert);
    //xml.SaveToFile(savepath)
    //Launch();
    batch.text:=dirapp+'7za.exe a ' + savepath + 'movies.zip ' + savepath + '12temp34\*' + #13#10 + 'rmdir /S /Q ' + savepath + '12temp34';
    xml.Free;
    exportxml.free;
    batch.free;
    showmessage('FINISHED!');
now i have a other question because now i create a custom html template for me i have a problem
now it look like
<html><head>
<style TYPE="text/css">
  body { margin: 0em; padding: 0em; }
  text,p,div,span,th,td,ul,li { FONT-SIZE: 10pt; FONT-FAMILY: Trebuchet MS, Verdana, Arial, Helvetica, sans-serif; color: black; background: white; }
  div.header { font-size: 18pt; font-weight: bold; text-align: center; color: white; background: black;padding: 5px}
  div.header2 { font-size: 10pt; font-weight: bold; text-align: center; color: yellow; background: black;padding: 5px; margin-bottom : 5px}
  div.footer { font-size: 18pt; font-weight: bold; text-align: center; color: white; background: white; padding: 0px; margin-top : 5px}
  hr { border: solid; border: 0; background-color: #000; color: #000; height: 3px; }
  A:link { COLOR: #003399; background: white; }
  A:visited { COLOR: #003399; background: white; }
  A:hover { COLOR: #CC0000; background: white; }
  A:active { COLOR: #CC0000; background: white; }
  tr { vertical-align: top; padding : 0px; }
  td.wh, table.wh { color: black; background: white; border: solid; border-color: white; vertical-align: middle; }
  td.gr { color: black; background: #F5F5F5; border: solid; border-color: white; vertical-align: top; }
  td.blk { color: white; background: black; border: solid; border-color: black; vertical-align: middle; }
  table { color: black; background: white; border: none; }
</style></head><body>
<div class="header">$$ITEM_TRANSLATEDTITLE ($$ITEM_YEAR)</div>
<div class="header2">"$$ITEM_CF_TAGLINE"</div>
<table border="0" cellspacing="0" cellpadding="0" width="100%">
  <tr>
    <td class="wh" width="200"><img src="$$ITEM_PICTUREFILENAME" alt="poster" width="200" /></td>
    <td>
      <table border="0" cellspacing="0" cellpadding="1" width="100%">
        <tr>
          <td class="gr">$$LABEL_ORIGINALTITLE:</td>
          <td class="wh">$$ITEM_ORIGINALTITLE</td>
        </tr>
        <tr>
          <td class="gr" width="165">Gesehen/Nicht Gesehen:</td>
          <td class="wh">$$ITEM_CF_GESEHEN</td>
        </tr>
        <tr>
          <td class="gr" width="150">$$LABEL_RATING:</td>
          <td class="wh">$$ITEM_APPR10 ($$ITEM_RATING) from $$ITEM_CF_VOTES Users</td>
        </tr>
        <tr>
          <td class="gr">$$LABEL_COUNTRY:</td>
          <td class="wh">$$ITEM_COUNTRY</td>
        </tr>
        <tr>
          <td class="gr">FSK:</td>
          <td class="wh">$$ITEM_CF_FSK</td>
        </tr>
        <tr>
          <td class="gr">$$LABEL_LENGTH:</td>
          <td class="wh">$$ITEM_LENGTHmin</td>
        </tr>
        <tr>
          <td class="gr">$$LABEL_CATEGORY:</td>
          <td class="wh">$$ITEM_CATEGORY</td>
        </tr>
        <tr>
          <td class="gr">$$LABEL_DIRECTOR:</td>
          <td class="wh">$$ITEM_DIRECTOR</td>
        </tr>
        <tr>
          <td class="gr">$$LABEL_PRODUCER:</td>
          <td class="wh">$$ITEM_PRODUCER</td>
        </tr>
        <tr>
          <td class="gr">Studio:</td>
          <td class="wh">$$ITEM_CF_STUDIO</td>
        </tr>
        <tr>
          <td class="gr">Writer:</td>
          <td class="wh">$$ITEM_CF_WRITER</td>
        </tr>
      </table>
    </td>
  </tr>
</table>
  <!--<tr>
    <td class="gr" width="150">$$LABEL_ACTORS:</td>
    <td class="wh">$$ITEM_ACTORS</td>
  </tr>-->
  <tr>
    <td class="gr">$$LABEL_DESCRIPTION:</td>
    <td class="wh">$$ITEM_DESCRIPTION</td>
  </tr>
  <tr>
    <td class="gr">$$LABEL_COMMENTS:</td>
    <td class="wh">$$ITEM_COMMENTS</td>
  </tr>
  <tr>
    <td class="gr" width="150">$$LABEL_URL:</td>
    <td class="wh"><a href="$$ITEM_URL">$$ITEM_URL</a></td>
  </tr>
  <tr>
    <td class="gr" width="150">Pfad:</td>
    <td class="wh"><a href="$$ITEM_CF_PFAD">$$ITEM_CF_PFAD</a></td>
  </tr>
</table>
<div class="footer"></div>
</body></html>
but i have a problem with the actors (that why there are deactivied)
my actor field has the folling value:
Sean Penn (Paul Rivers | http://ia.media-imdb.com/images/M/MV5BMTc1NjMzMjY3NF5BMl5BanBnXkFtZTcwMzkxNjQzMg@@._V1._SY314_SX214_.jpg | http://akas.imdb.com/name/nm0000576/), Naomi Watts (Cristina Peck | http://ia.media-imdb.com/images/M/MV5BMTMyODUxOTk0MF5BMl5BanBnXkFtZTcwNjE0NDc2Mw@@._V1._SY314_SX214_.jpg | http://akas.imdb.com/name/nm0915208/), Danny Huston (Michael | http://ia.media-imdb.com/images/M/MV5BMTc0MDQyMjM2OV5BMl5BanBnXkFtZTcwNjc2NzMzMw@@._V1._SY314_SX214_.jpg | http://akas.imdb.com/name/nm0396812/), Carly Nahon (Cathy |  | http://akas.imdb.comhttp://pro.imdb.com/widget/resume_redirect/), Claire Pakis (Laura |  | http://akas.imdb.comhttp://pro.imdb.com/widget/resume_redirect/), Benicio Del Toro (Jack Jordan | http://ia.media-imdb.com/images/M/MV5BMTkzODQ4NzU1N15BMl5BanBnXkFtZTcwOTUzMzc5Mg@@._V1._SY314_SX214_.jpg | http://akas.imdb.com/name/nm0001125/), Nick Nichols (Boy |  | http://akas.imdb.comhttp://pro.imdb.com/widget/resume_redirect/), Charlotte Gainsbourg (Mary Rivers | http://ia.media-imdb.com/images/M/MV5BNDQyMzQ5NTEzNl5BMl5BanBnXkFtZTcwNjI3NTEzNQ@@._V1._SY314_SX214_.jpg | http://akas.imdb.com/name/nm0001250/), John Rubinstein (Gynecologist | http://ia.media-imdb.com/images/M/MV5BMTcxNjM1OTk4MV5BMl5BanBnXkFtZTcwNjI1NjA2Mw@@._V1._SY314_SX214_.jpg | http://akas.imdb.com/name/nm0748270/), Eddie Marsan (Reverend John | http://ia.media-imdb.com/images/M/MV5BMjIzNjk0MTAxNV5BMl5BanBnXkFtZTcwMTA2NjQ0Mw@@._V1._SY314_SX214_.jpg | http://akas.imdb.com/name/nm0550371/), Loyd Keith Salter (Fat Man |  | http://akas.imdb.comhttp://pro.imdb.com/widget/resume_redirect/), Antef A. Harris (Basketball Guy |  | http://akas.imdb.comhttp://pro.imdb.com/widget/resume_redirect/)
actorname (role | actorpic | actorpage)
and now i want that in the html file it look like
actorname (with link to the page) ... role
Sean Penn ... Paul Rivers
Naomi Watts ... Cristina Peck
and so on
how can i do that
sry that i asked so many questions^^
You won't be able to generate links automatically using the HTML export.
Only solution would be to include Javascript in the page that will convert links when the page is loaded in a web browser.
I-Catch
Post by I-Catch »
i don't want to export i mean the html in the program itself
http://mickaelvanneufville.online.fr/AM ... pture1.png
Post by soulsnake »
Another solution is to create a custom field (e.g. ACTORS_HTML) of type TEXT and you fill it using a script that format field ACTORS like you want for html export/display.
This way you can use custom field (e.g. ACTORS_HTML) in your template with actors formatted like you want !
vunvun
Post by vunvun »
hi,
I'm new here. Can you please explain how to run the script to export the movie data to Movielicious for android. Thanks in advance.
sweborn
Post by sweborn »
:grinking: Good question.. I also want to know how to export to an Movielicious zip file.
Edit: NO RESPONS!
jandes
Post by jandes »
sorry for my bad english
I modified the code write by I-catch and work fine,
Authors=
Title=Movielicious export
Description=Exports Movies to Movielicious XML format
Site=
Language=?
Version=
Requires=4.1.1
Comments=
License=
SoulSnakeUtils ;
  xml: TJvSimpleXml;
   savepath = 'C:\Users\jan\Desktop\catalog\';
  //savepath = 'Z:\media\Daten_2TB\movies\';
  lstActor.Free;
  seen:string;
//  eMovie.Items.Add('CatalogNr');
//  eMovie.Items.GetItemNamed('CatalogNr').value := GetField(fieldnumber);
  eMovie.Items.GetItemNamed('Media').value := GetField(fieldMediaType);
  eMovie.Items.Add('Genre');
  eMovie.Items.GetItemNamed('Genre').value := GetField(fieldCategory);
//  eMovie.Items.Add('Notes');
//  eMovie.Items.GetItemNamed('Notes').value := GetField(fieldcomments);
  eMovie.Items.GetItemNamed('Position').value := GetField(fieldMedia);
  eMovie.Items.GetItemNamed('Seen').value := GetcustomField('Visto');
  AddMovieData;
    //Launch();
//    batch.text:=dirapp+'7za.exe a ' + savepath + 'movies.zip ' + savepath + '12temp34\*' + #13#10 + 'rmdir /S /Q ' + savepath + '12temp34';
//    batch.savetofile(dirapp + 'start.bat');
//    Launch(dirapp + 'start.bat','');
    xml.Free;
    exportxml.free;
    batch.free;
but there is an error in the original code; the function ActorsToXml not work and return only commas
