Bug in IMDB script (EN) -any workaround?
Bily
Post by Bily »
Example:
http://imdb.com/title/tt1506999
For "Description" field the Tagline is imported: They left her no choice.
The short summary at the top should be imported:
A black ops super soldier seeks payback after she is betrayed and set up during a mission.
How can I change this in the script?
BTW, I have "0" as the selection in Script Options for DescriptionSelection.
Thanks in advance. ;)
It seems to work for me...
Which version of the script do you have?
Bily
Post by Bily »
Version 3.73
Windows 7 64 (if it matters)
EDIT: Sorry, my fault. I had put awards to be inserted in front of description and, for some reason, the consequence of that was that the Tagline took the place of the short IMDB summary at the top of the page in the description box.
Once I removed the awards, all is working.
Will go hide under a rock for a while. :(
