Wishlists for new versions.
jermine01
Post by jermine01 »
Some suggestions to make this movie catalog even better.
1. Imdb User Ratings and number of votes should be in separate fields.
2. Tagline field and MPAA field are both downloaded to the comments field. I would like them to go to separate fields. There seems to be a shortage of fields. Can anyone point me to a tutorial on using custom fields?
3. A movie thumbnails field would be nice.
4. 10 star ratings as on the imdb site and not 5 star as of present.
