I use AMC and Myfilms/AMCU and I'd like to make the grabbing consistent between them.
AMCU puts the Classification in a Custom field "Classification" so I'd like to make AMC's IMDB script do the same. At the moment it offers the option to put it in the Media Label or Comments field, but I want to use the Media Label field for it's proper purpose and want the Classification in it's own field, rather than comments, so that I can sort/group by it.
AMCU also puts the Tagline in a Custom field. I'm not decided on whether I prefer that or having it at the start of the Description, as AMC does now, but I'd like to know how to modify the AMC IMDB script to put the Tagline in the Custom field if I decide to.
Modifying IMDB script
AMCU = http://sourceforge.net/projects/amcupdater/ ? (I found that with Google, I didn't even know it existed)
For the IMDB script, you could search where it sets the value (using SetField) and replace that by a SetCutomField call.
e.g. if there is a
SetField(fieldMedia, SomeVariable);
you could put
SetCustomField('ClassificationFieldTag', SomeVariable);
where SomeVariable is the variable used in the script
and ClassificationFieldTag is the tag associated to the custom field (to be put with the quotes)
e.g. if there is a
you could put
doveman
doveman
OK, looks like the relevant section is
so if I set Classification setting to 1 then can I just modify the latter part to:
where Certification is the custom field?
if GetOption('Classification') > 0 then
if UserCountry = '' then
ShowMessage('Country not set for classification selection - Click "Editor" tab in the scripting window, then select your country by modifying the required line as explained in the first lines of the code')
Value := TextBetween(PageText, '<a href="/search/title?certificates=', '</div>');
Value := TextBetween(Value, UserCountry + ':', '</a>'); if Value <> '' then
if GetOption('Classification') = 1 then
SetField(fieldMediaType, Value)
SetField(fieldComments, GetField(fieldComments) + #13#10 + #13#10 + 'Classification: ' + Value);
end;Code: Select all
SetCustomField('Certification', Value)
end;-
spiderman
import studio / production company
I would like an import function for production company.
thanks in advanced
thanks in advanced
