Hi, my name is Angel, I apologize for my English, I would have some suggestions about the program Ant Movie Catalog. I think I understood that to read the video file is used Mediainfo the program and then reads the entire data.
But one thing is missing on the program (maybe I am too meticulous) the field with the file extension (MKV, AVI, etc..) Is the first thing one sees your files. Then I see the video format. The audio channels, I mean, the program recognizes the type of audio but does not say how many audio channels, in particular the wording is: AC3 or DTS and enough, but how many channels? Some movies are a bit old and have 1 or 2 channels other facts a bit wrong i have 5 new ones have 6 or 7. It would be better to explain in a detailed audio AC3 6 Ch or AC3 Ch 2 in this case in my catalog that I already know that file was 2 0 6 channels. the same goes for DTS, again does not say much, does not say if it is a DTS 6 Ch or DTS 2 Ch or DTS-HD 6 Ch. Other small changes, in discs, perhaps here was inserted the figure for how many CDs or DVDs you have for a film, you can do something for those who have transferred to all on the hard disk? and then a field type HD 1, HD 2? I hope I was clear in the explanation and that it is possible to make these changes. I am not a programmer and maybe what I asked for is impossible, but to change hundreds of files is not funny. I wish I could enter my hard disk and update the catalog. For the rest of the program is exceptional.
Salve, mi chiamo Angelo, avrei dei suggerimenti sul programma Ant Movie Catalog. Credo di aver capito che per leggere i file video venga usato il programma Mediainfo e quindi legge per intero i dati.
Manca però una cosa sul programma (magari sono io troppo meticoloso) il campo con l'estensione del file (MKV,AVI ecc.) è la prima cosa che uno vede del proprio file. Poi vedo il formato video. I canali audio, mi spiego, il programma riconosce il tipo di audio ma non dice quanti canali audio, in particolare la dicitura è: AC3 o DTS e basta, ma quanti canali? alcuni film sono un po vecchi e hanno 1 o 2 canali altri fatti un pochino male ne hanno 5 i nuovi ne hanno 6 o 7. Sarebbe meglio spiegare nel campo un audio dettagliato tipo AC3 6 Ch oppure AC3 2 Ch in questo caso nel mio catalogo so già che quel file è 2 0 6 canali. lo stesso vale per il DTS, anche qui non dice altro, non dice se è un Dts 2 Ch oppure DTS 6 CH o DTS-HD 6 Ch. Altra piccola modifica, nel campo dischi, qui forse veniva inserito il dato per quanti cd o dvd si ha per un film, è possibile fare qualcosa per chi ha trasferito tutto su hard disk? e quindi fare un campo tipo HD 1, HD 2? Spero di essere stato chiaro nella spiegazione e che sia possibile poter effettuare queste modifiche. Io non sono un programmatore e magari quello che le ho chiesto è impossibile, ma modificare centinaia di file non è simpatico. Io vorrei poter inserire il mio hard disk e aggiornare il catalogo. Per il resto il programma è eccezzionale.
