last change date
pippolino
last change date
Post by pippolino »
Hello,
I like the "auto fill current date" feature that saves the date in the xml file for each movie.
What I would like to see in addition is a "last modified date".
Why?
For example I use the checked field to mark the movies I have seen.
I can add details to a movie and so on...
After that, I would like to be able to find stuff that has been modified in the last week.
It would also be useful for people that use external scripts to parse the db file and generate for example movie sheets images from that comaptible with media players. It would be possible to parse only movies that have something changed from the last generation and save a lot of cpu work.
Simply saving the modified date for each movie could have a lot of powerful usages...
Ciao!
