Version 3.4.2
What's new in Ant Movie Catalog, beta versions, etc...
Version 3.4.2
New version, which adds few small things :
* Import/Export with Origons website.
* Few new options in Export options, in the Preferences window.
* Few bug corrections.
You can download it here :
ftp://pub.antp.be/antp/software/amc_install.exe
I updated IMDB script to correct a problem : pictures was stored as external file, and I guess that most of users prefer to have the pictures stored in the .amc file (even if it makes the file a little long to load).
To change that it is quite easy. You can either re-download the scripts to get the large pictures stored in the catalog by default, or change the script yourself. In the lines GetPicture(Value, True); replace the True by False to store the picture in the catalog.
I also updated few translations : Romanian, Polish, Bulgarian, Italian, Norwegian, Turkish.
full install:
only scripts:
ftp://pub.antp.be/antp/software/amc_scripts.zip
only translations:
ftp://pub.antp.be/antp/software/amc_lang.zip
Few added & updated scripts.
Updated Catalan, Finnish, Hungarian, Portuguese and Spanish translations, and added a Slovak translation.
Again, updated and added some scripts and translations.
(new translations: Swedish, european Portuguese, Serbian)
I updated and added few scripts.
Again, scripts and languages updates.
Script include All Movie Guide, Allociné, IMDB, and few new ones.
And again, scripts and templates have been updated :)
And again a scripts update, for IMDB and Allociné ;)
