Resizing Fields
Resizing Fields
I would like to resize a field in main window: i tried changing my language file this way:
EComments.Hint=|invio ricevuta
EComments.Visible=1
EComments.height=22
EComments.width=60
but only width parameter is useful and field's height doesn't change.
Is it possible tho change field height? how?
Thanks. ;)
The comments field is resized by code, when resizing the window, to share the remaining space with the description field, hence why the height is not kept.
antp wrote:The comments field is resized by code, when resizing the window, to share the remaining space with the description field, hence why the height is not kept.
Well, I hoped new version could change this.... :ha:
Anyway, is this a problem about all fields?
The other hand, I saw it's easy to change field's width, isn't it?
Thanks.
The only other field of which you could change the height is the actors field (for other ones, I do not see the point as they are not multiline). If you move other fields (by changing top & left values) it can be useful.
Thanks, that's all.
