Added date from import doesn't work in filter
Mautsen
Post by Mautsen »
I update to the last version 4.1.0.2 and I have find a problem.
When I filter the groups by DATE ADDED, some titles are listed
by OTHERS and not by date added. (see image)
Though the titles have their own date added. But all these titles where imported from a other ANTmovieCatalog file.
Can that be solved that the movietitles are correct been placed by date added,
thanx anyway
Carl
Image[/img]
Post by soulsnake »
Just go in Preferences > Movie list > Grouping and uncheck "Put in a special common group items that would been alone in their group". ;)
Mautsen
Post by Mautsen »
Hi soulsnake,
Thanks a lot! It works fine now.
Very appreciate for the fast help.
Kind regards
carl
