I've hit a problem with v4.1.0 where after opening, if the first new record I add is a multi-file movie, it creates two new records rather than a single record with 2 files.
It only happens if it's the first record after opening AMC. If I then delete the 2 records which have the media info, create a new record, and drag'n'drop the 2 files onto the record it then populates the media info fields correctly.
Repro:
1. Open AMC with existing catalog
2. Drag'n'drop multi-file movie files onto the default new record
3. A new record is created for each file
4.1.0 - Problem when first new record added is multi-file
AnthonyB
