Export HTML format: How do I change to another template?
MediaCult
Post by MediaCult »
Hi.
The standard export for HTML using "template.html" doesn't look good, mainly because the image files are their own size so they vary a lot.
I want to use the template called "HTMLDefaultTemplate" for export.
How do I do that?
Simply:
1) Export (from Main Menu)
2) choose HTML format
3) clic on label "Full"
4) clic on icon "load" and load the template you choose for catalog index
5) clic on label "Individual"
6) clic on icon "load" and load the template you choose for single movies of your catalog
7) export.
MediaCult
Post by MediaCult »
Thanks. For some reason it only works for the individual option, full option is just a blank template. Why is that?
MediaCult wrote:Thanks. For some reason it only works for the individual option, full option is just a blank template. Why is that?
You mean You obtained an empty index page from your export or what?
Anyway, wich full template did you loaded?
give us its name please.
MediaCult
Post by MediaCult »
I realized that I loaded an individual template, not a full one.
Thanks anyway :)
