little hint
Bacillo
little hint
Post by Bacillo »
I think AMC has a good output, but it is less usable in the import
What should be there for me in the AMC has a module "IMPORT" to add anything you can for example hard disk.
You should explain a little more what you mean by that, and what you would expect as behaviour from the program...
Re: little hint
Bacillo wrote:I...... AMC has a module "IMPORT" to add anything you can for example hard disk.
visto questo viewtopic.php?t=3865&highlight=imtoamc ?
did you see viewtopic.php?t=3865&highlight=imtoamc ?
If it s just importing files, since AMC 4 it is now possible to do that directly in the program (File->Import)
