It seems to me that i am no longer allowd to add new films. When i try, a new (empty) record is created but i'm not allowd to enter information. No error reports.
I tried to make een new database. Same problem.
New install, Same problem
Where am i going wrong?
Best regards
Gerald
Problems adding new record
I try to reproduce the bug without success.
Can you give me more details such as:
- OS: Windows XP / Windows Vista / Window 7 / ...
- Version: Installed / Portable
- If installed version: First install / Uninstall v3.5.1 and install v4.1.0 / Update to v4.1.0 without unistall v3.5.1.
Can you try portable version (if you use installed version) and say to me if you have the same problem ?
Thanks,
Thanks,
