Join archiv
Bacillo
Join archiv
Post by Bacillo »
Sorry, I'm here with other questions.
- And 'possible to merge two archives AMC? Or alternatively import an archive AMC data from another store?
- It 's possible to edit / change "columns" complete archive
thanks
To merge two AMC files, either import one in another, or both in a new catalog. You can do that with File -> Import.
For your second question, you mean change the value of a field in all movies?
Bacillo
Post by Bacillo »
Yes y, change the value of a field in all movies.
YoungBoy
Post by YoungBoy »
I don't understand what you want change.
The fields in main movie aren't editable (or edit source code and recompile). Custom fields are all editable and more more more (great idea by @soulsnake)
[Italian language: Non ho capito cosa vuoi cambiare nei campi. Quale valore? I campi della finestra principale non sono editabili a meno che di non modifcare il codice, mentre quelli della finestra personalizzabile ci puoi fare quello che vuoi]
Bacillo wrote:Yes y, change the value of a field in all movies.
There is a script named "update fields" that allows to do that easily (tools -> scripting)
Bacillo
Post by Bacillo »
I have seen and tried a little harder to use, but I'll learn.
thanks
